Auto Spring Front only OR Complete?
Guys, I'm looking for some general advice on a leveling kit.
I'm looking to add a 2" Auto Spring to my 2011 screw cab. However i'm not certain on whether to go with just the front only, or go with the complete kit?
I'll be going to either a 275/70/18 or 285/65/18 for my next tire.
Pros and Cons to either? Thanks,
I'm assuming the full kit means either blocks of add-a-leafs in the rear?
If so basically, do you want it level or do you want the factory rake?
If you tow do you want the back to sit lower while towing or do you want it to be level while towing?
my old truck has pretty much the same set-up your talking about,, autospring 2" front spacer with a 3" block in rear with 275/70/18 rugged terrains,
