My left cheek seems to be sagging
Alright...my cheek isn't really sagging, however it appears that the back driver's side of my truck is sagging a little bit. Should I take it into the dealer here in Auburn, or is there some way that I can do it myself. I would rather do it myself, if all possible. It is more fun that way. I just don't like to walk up behind my truck and it look lopsided. Anyone with suggestions please reply...thanks Meek
Hi Meek,
I think I have the same problem as you. I brought my truck in the shop last week and they changed the left leaf spring. A day later it was still sagging on the left side. I am going back tonight as they will investigate some more. Did you manage to have your sagging problem fixed?
Thank,
Stephane
Thank,
Stephane
I have a 2001 SCrew.....had a 1998 Explorer. Both have the rear left corner sag. I am told that the position of the fuel tank and weight of the fuel tends to generate the "permanent" sag.
On my SCrew, the left rear was about 1 inch lower than the right rear.
With the rear end jacked up, I tried loosening the leaf spring U-bolts (on axle) on both sides and rapping hard with a 2 lb hand sledge to "settle" the springs a bit. It helped level it out by a quarter inch, but you can still notice the remaining sag of 3/4 of an inch.
Take it in to the dealer if under warranty and tell them to replace both rear leaf assemblies. I'll be doing the same soon.
