Sponsored by: CARiD
Looking to lower my 07 screw
Old Oct 16, 2013 | 08:51 PM
OP, are you 4x4 or 2wd? Nevermind, I see AWD. Start by removing block, and putting 2wd struts on. Should get you around a 2/2 drop.
Originally Posted by RANGERansom
i had trouble getting my truck to align perfect, she was at -1* camber. which is fine, but i want it zeroed out
send me a copy of your spec sheet please
Old Oct 16, 2013 | 09:11 PM
RANGERansom's Avatar
If I can find it... I have a die grinder and a deburring bit but I'd rather buy the cam washer kit than take out the entire lca assembly again...
Old Oct 16, 2013 | 09:36 PM
429 boss mustang's Avatar
I might be interested in this too :3
Old Oct 16, 2013 | 09:53 PM
It's 68 bucks total! That hole is standard procedure. Your factory bolts sit in there just by themselves. This isn't much different, I'd say even safer. I'm happy
Old Oct 22, 2013 | 12:29 PM
maxpat82's Avatar
I have a 3/5 DJM drop on my 07 fx2 Scab with slam air helper bag.
I tow my 7000lbs toy hauler and it tow great.
can put 1500lbs of payload whitout having it sag or it the frame on every bump (helper bag are the key.
My complete kit will be for sale this winter only 2 year with less then 20K km.(i'm in montreal, qc)
Old Oct 22, 2013 | 08:53 PM
07massHD's Avatar
Going to keep researching. Thanks for all the replies and also maxpat82 I sent you a pm.
Old Oct 28, 2013 | 10:08 PM
tbear853's Avatar
yes i know, but essentially that little pin that goes in the insertion hole is taking all the stress is what im saying... i guess its good for you then ill look into buying one! how much doll hairs did it cost u?
The factory holes are slotted and whet holds the adjustment is simply friction after the bolt is torqued.
The kit locates in the holes, lets the mechanic adjust by turning the nut, and then lock by torqueing it .... so you have the friction as before .... plus that pin which has at least some couple thousand pounds shear strength.
