Lifting my '03 F150 4wd
So after reading through more threads than I can count to, I figured I would start one regarding a lift kit for my truck. I honestly know very little about lift kits, so any help is greatly appreciated. I am looking for something between 4-6 inches, and want a suspension lift, not a body lift.
I'm currently looking at Fabtech, Procomp, or Rough Country as my choices, however some have a 6" lift for $500, while others have a 6" lift for $1,400. Obviously this is where I get confused. Are the cheaper kits "cutting corners" so to speak? I see some with springs, some without. Others have blocks with add-a-leaf, others don't.. etc etc.
I plan on using it as a daily driver, and will never be doing any heavy hauling with it, just a snowmobile trailer most likely.
Perhaps I could list what the kits include and you guys could help me from there? Thanks in advance for the help!
Yeah I realize that now, hence why I ask before buying haha. Rough Country has a 5" kit I am liking, component list is as follows.
Front
◾Lifted knuckles
◾Upper skid plate
◾Differential skid plate
◾Front 3-piece crossmember
◾Rear 3-piece crossmember
◾Extended sway-bar links
◾Bump-stop brackets
◾Torsion bar drop brackets
◾Hardware
Rear
◾4in lift blocks
◾U-bolts
◾Hardware
Shocks
◾(4) Premium N2.0 series
Haven't decided on wheels/tires yet, but is regearing a must in your opinion? Looking at 33's, maybe 35's.
Front
◾Lifted knuckles
◾Upper skid plate
◾Bump-stop brackets
◾Hardware
Rear
◾4in lift blocks
◾U-bolts
◾Hardware
Shocks
