Sponsored by: CARiD
Burning Smell
Old Mar 15, 2013 | 03:10 PM
JstabFX4's Avatar
Burning Smell
Not sure if I have this question in the right area, but I just noticed this when I walked around my truck today. There was a burning like smell coming from around my passenger front tire. Not sure what would be the cause. Its a 2006 FX4, any help would be appreciated, Thanks.
Old Mar 15, 2013 | 03:28 PM
kingfish51's Avatar
Most likely a stuck caliper, causing the brakes to overheat. Get it fixed soon or you will be replacing more than just pads.
Old Mar 15, 2013 | 03:35 PM
Seized caliper? That one seems to go bad on these trucks a lot. Twice to me so far
Old Mar 15, 2013 | 03:53 PM
JstabFX4's Avatar
So is a seized caliper an expensive fix, or can I do it myself? And thanks for the help
Old Mar 15, 2013 | 04:15 PM
kingfish51's Avatar
Your best bet is to replace the caliper. You may have to replace pads and rotors. those should be replaced on both sides. I believe with the anti-lock brakes, bleeding is not a straight forward process.
That assumes that the problem is the caliper.
Old Mar 15, 2013 | 05:16 PM
I will *strongly* advise changing all flex lines. I'm doing that to mine since I'm loosing my 2nd caliper on that one spot.
Old Mar 15, 2013 | 05:42 PM
kingfish51's Avatar
When you replaced your calipers, did you get the upgraded ones? The 04 had a big problem with calipers sticking and the changed the design of caliper and rotor, both front and rear. Once this was done, the problem seemed to go away. Now with a vehicle 7 or more years old, I can see it happening no matter what the design as age causes component to degrade.
Old Mar 17, 2013 | 04:06 PM
I did but not the flex lines. The brakes aren't even a year old
