Sponsored by: CARiD
When to Torque Down Suspension
Old Mar 18, 2013 | 12:42 PM
SP1's Avatar
SP1
Hey guys, New member here. Been searching around and I cant seem to find the answer to this. I found the torque sepcs for the front end, but when re installing the shocks (Quicklift) should I just get them tight, put the wheels on, drop it off the jacks and then finish torquing the bolts down or just do it all at once when reassembling? I've read the front can bind if you torque it down while still in the air.
SP
Old Mar 18, 2013 | 02:10 PM
kingfish51's Avatar
SP
The binding is with other components such as sway bars, upper/lower a arms etc. The shocks can be torqued at any time, extended or compressed.
Old Mar 18, 2013 | 02:37 PM
SP1's Avatar
SP1
So go ahead and torque the shock while in the air and then torque the sway bar and upper a-arm once on the ground?
Old Mar 18, 2013 | 03:58 PM
kingfish51's Avatar
My mistake, I thought you were just doing shocks. As you are doing the whole suspension, I would wait till on the ground. If just shocks, there is no need to wait.
Old Mar 18, 2013 | 04:23 PM
SP1's Avatar
SP1
Yeah, Rancho says you need to unhook the uppers and the sway bar for instal. They show torquing the shock down before putting the wheel on but dont mention when to torque the uppers or sway.
