Sponsored by: CARiD
Spring Swap
Old Feb 15, 2013 | 04:04 AM
MDBarts's Avatar
Spring Swap
I have a 1996 F-150. would I be able to take the rear leaf springs and front coil springs out of an F-250 of the same era and put them in my truck without making any drastic modifications to my truck? Thanks!
Posted from F150online.com App for Android
Old Feb 15, 2013 | 01:14 PM
Buxton91's Avatar
I've seen guys do this before on here. You'll gain about 2" of lift up front, unsure about the rear.
Old Feb 15, 2013 | 02:03 PM
MDBarts's Avatar
@Buxton91 Sweet ****! the spring and the shock or just the spring?
Old Feb 16, 2013 | 03:16 AM
Buxton91's Avatar
You should be good with factory size shocks.
Old Feb 19, 2013 | 01:03 AM
Buxton91's Avatar
Originally Posted by tomwatson
now a days very awesome technologies are in demand...its a hope of better and fastest transport in the world....
The most horrible attempt at spam I've ever seen.....
Old Feb 19, 2013 | 01:07 AM
pizzaman711's Avatar
How he managed 12 posts is beyond me
Old Feb 19, 2013 | 08:37 AM
dirtrider596979's Avatar
Look at his vechical description it says its a 2001 Honda f-250 Fail
Old Feb 19, 2013 | 09:16 AM
MDBarts's Avatar
yeah, the spammer is obnoxious, but can we get back to the original question of switching suspension? I know the leafs are 2.5" on the 150 and 3" on the 250. Will I need to use the brackets off the 250, or will everything line up?
Old Feb 19, 2013 | 10:37 AM
1997 lariat 4.6's Avatar
you'll need teh brackets off the f250. but you should be good. Heck you will pretty much have an f250 when your done...
Old Feb 19, 2013 | 11:21 AM
MDBarts's Avatar
@1997lariat4.6 thanks a lot, bud!
Old Feb 19, 2013 | 11:25 AM
yep, you MAY need to drill holes to match, but i doubt that will be needed.
Old Feb 19, 2013 | 12:35 PM
You'll need to swap the spring perches from the f250 over also, not just the shackles.
And have you already measured th eye to eye distance on them to see if they're the same size as yours? And if they do swap the ride most likely be rough due to the fact the f250 springs won't have as much weight on them as before.
Old Feb 19, 2013 | 04:28 PM
MDBarts's Avatar
I found some "leaf helper springs" at O'Reillys that boost the load capacity by 1,500lbs. I'd upload a pic, but I can't from my phone. It's a simple bolt on assembly. Has anyone used these?
Old Feb 19, 2013 | 05:23 PM
Add-a-Leaf? They're commonly used, give around 1.5-2" of lift.
However even with the added capacity of those and the f250 springs you still can't go over what your truck is rated for.
Old Feb 19, 2013 | 07:33 PM
MDBarts's Avatar
not add a leaf, its a little different. it bolts to the bottom back of the leaf pack.
