Upgrading to Coilovers... TUNE IN
Hey guys
Havent been on the forum in yrs but thought I'd stop by for an update.
I've been running my Fabtech stage 1 lift kit on my F150 for a little over 4 yrs now. Not too many complaints with it except my struts are starting to wear out. my passenger strut is starting to leak a little bit and my truck is slowly starting to ride like a dump truck
Im the type of person that when i replace a part I upgrade. So I figured instead of buying new Fabtech struts i would upgrade to coilovers.
After a little research i decided on Sway-A-way. I looked into Dirl logics, Pro-comps, Kings ect. Sway-A-Way was a no brainer decision for me.
My coilovers were built and shipped out 2 days ago. Once i receive them i will install them and post tons of pics. I "might" do a writeup on the install.
So here is what im starting with. My truck is my DD/tow rig for my Jeep.
And heres my other toy
STAY TUNED
STAY TUNED
Not to start a pissing contest, but your truck has coil-overs now; that's what the stock items are. They're not struts even though some stores refer to them as such. You're simply upgrading to aftermarket coil-overs.
going to start the install today.
How do I look confused? I researched different bolt in coilovers and settled on Sway-a-way coilovers built for a 2004-2008 F150 2WD with a 6" fabtech lift. sounds pretty straight forward
Well Im pretty much done with the install.
Heres my little, basic write up.
First heres the most recent pic I have of the truck. This is from just a couple days ago
First thing I did was obviously jack up the front and remove the tires
Heres a pic of the my old setup.
Next I unbolted the upper control arm from the knuckle. after that I unbolted the upper and lower mounting on the Fabtech strut and removed it.
Everything removed
Fabtech strut next to Sway-a-way Coilovers.
And another
Next all you do is put everything back together in reverse order. Its a real easy job and doesnt take long at all
finished with the new coilovers
the truck looks level in this pic but its not. I still need to crank the coilovers for about 1-2" more lift. I'll get to that tomorrow
Thats all guys
Everything removed
And another
Thats all guys
