Best Levels for 03' F150
I wanna get a level for my F150 and have been looking at a few options, but it has come down to either coil spring spacers, or the actual coil spring. I've been really looking into the Rough Country 2" coil spring level kit, but I wanna know what the rest of the f150 world recommends, and yes price is a factor.
I'd go with a 3" spindle kit with a 1" rear block over a coil spring or spacer. It will keep your ball joint angles stock and not change the ride quality at all. Price wise, it's still relatively cheap ($350-$500 IIRC)
Wait for pizzaman or buxton to chime in, they are much more familiar. I believe pizza is running spring tech, not sure about buxton.
no shocks in this kit, but i believe a kit is offered with shocks if you need them
http://www.ebay.com/itm/1997-2003-Fo...ac63da&vxp=mtr
rough country w/ shocks
http://www.ebay.com/itm/Ford-F150-3-...e#ht_954wt_952
Me and Buxton are both running springtech. Probably the most affordable brand out there and the springtech spindles are 3.5" so if you decide you want to go to 35's later it's easier to do because you can just add the 3" coils with the aftermarket arms. Opposed to the 3" rough country spindles which not only would you need the coils and the arms but you'd probably have to do a body lift also because 6" is just barely not enough for 35's where with 6.5" it's a lot better fit because you need very minor trimming if any.
If you go with the spindles I'd go with somewhere around a 1-1.5" block depending on what height spindle you get to make it level. And with the spindles you'll need stock length shocks so those are little cheaper than lifted height applications. Shock wise I'd go with the procomp 9000's, rancho 9000's or the bilstein hd's since it'll require stock height ones.
Since you'll be tearing down the front end anyways to do the install no matter what form of level you decide on I'd plan on replacing upper/lower balljoints and the outer tie rods. If they're about 70k old it's most likely time for them anyways and it'll make install a whole lot easier if your not worried about damaging the old ones to reuse them.
For the front, no. For the rear, depends on which size block you get with the kit.
If you do have the original shocks on your truck, i'd replace them as they are probably shot.
Sounds like its what im going to end up getting...i see on one of those links that it ships from huntington beach, do you guys install too? because i could drivethere and do it all instead of having it shipped to me.
