Sponsored by: CARiD
Looking for oem type shock replacment
Old Jul 21, 2012 | 09:04 AM
lilfflippy's Avatar
Hi I'm looking for a OEM type shock replacement.
I currently like the way my truck currently rides with the OEM shocks
Please reply back thanks
Old Jul 21, 2012 | 02:05 PM
jbrew's Avatar
What truck, a Ford ? If so, what year, what model ? Look around, it should say somewhere. If not, check your title or registration.
Old Jul 21, 2012 | 03:09 PM
Galaxy's Avatar
Then roll on down to the dealership and pick up a stock replacement set...should serve you well.
Old Jul 21, 2012 | 03:42 PM
lilfflippy's Avatar
Its a 97 F150 4x4
Old Jul 21, 2012 | 05:20 PM
jbrew's Avatar
Right, if you like those cheap OEM's, then stick with'em. However, I think your the only one on the planet that does. Mainly, they just don't last.
Personally, I like the-
Edelbrock's (fav) - http://www.shockwarehouse.com/news/e...extreme_XT.cfm
RS9000 - http://www.shockwarehouse.com/site/r...s9000x_pro.cfm
Bilsteins- http://www.shockwarehouse.com/site/bilstein_7100.cfm
The direct OEM replacements, nothing fancy are good as well. Most go with Bilsteins.
Old Jul 21, 2012 | 06:01 PM
TURNMASTER's Avatar
I put in Monroe Sensatrak when I replaced shocks on my 2wd F150 (03). They were great for about 2 months. Seem to have softened up a bit. Overall I am disapointed. They are to soft. Bilsteins are next, I will replace them next spring.
Jeff
Old Jul 21, 2012 | 08:14 PM
Galaxy's Avatar
Another vote for Edelbrocks
Old Jul 23, 2012 | 07:33 AM
lilfflippy's Avatar
Jeff
Were the Monroe Sensa trac softer than the OEM shocks?
Old Jul 23, 2012 | 09:04 AM
Galaxy's Avatar
https://www.f150online.com/forums/su...st-shocks.html
Old Jul 23, 2012 | 12:58 PM
beechkid's Avatar
25 Year Member
Shock Recommendations IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
FYI- IMHO, when Monroe & Gabriel were the same company, their products were good quality & perf.....but today, I consider Monroe a "disposible shock", where gabriel is still of very good quality and backed by the mfg.
Old Jul 23, 2012 | 01:17 PM
lilfflippy's Avatar
What are your thoughts on Gabriel vst/ultra shocks?
Old Jul 23, 2012 | 01:32 PM
dewalt17's Avatar
I am loving the ride of my truck with my bilstein 5100's.
Old Jul 25, 2012 | 12:38 AM
TURNMASTER's Avatar
lilfflippy
Softer than stock? Yes I think they are.
Here is the thing though. I was starting to get extra bounce out of the factory shocks and when changing I found that 3 of 4 were leaking. The Sensatraks seemed pretty good right of the bat and with the stock size wheels and tires but ride seemed to degrade rapidly. When I put the L wheels and lower profile tires on, the bounce was back to almost as it was before.
Here is the thing, to soft of a shock will not dampen the spring and let the truck bounce. There is a link above from Galaxy that references this.
Now I tend to drive a bit more aggressively and that extra bounce drives me crazy. If I am simply driving like like an old man then all is good and if that is how you drive then no prob get the JUNK Monroes.
If you really like the factory ride and do not seek any improvement over stock just go to the dealership and buy a set from Ford. That way you will get the correct shock.
I was seeking an improvement and took advice from the guy behind the counter. Apparently him and I have a different idea of what a bit stiffer than stock is. Oh well, live and learn.
Jeff
Old Jul 25, 2012 | 12:52 AM
lilfflippy's Avatar
lilfflippy
Jeff
