Sponsored by: CARiD
Rancho Lift Finally on
Old Jul 4, 2012 | 01:30 AM
kitchenboy's Avatar
I forgot to mention the Toyos are the E load rating. I put the 5" block in, and the rear still measures about a 1/2" lower than the front. Might have to do a custom block or an AAL. Maybe even airbags, but was trying to avoid them since I never use the truck to tow or haul anything really heavy.
Old Jul 4, 2012 | 01:35 AM
kitchenboy's Avatar
After doing some searching, I guess a 5" block is the biggest you can get, so Im going to have to go another route to get the rear up a little bit.
Old Jul 4, 2012 | 01:52 AM
firefighterf150's Avatar
Looks awesome!
Old Jul 4, 2012 | 09:53 AM
fine_style150's Avatar
Looks great!! do a AAL in the back
Old Jul 4, 2012 | 02:50 PM
kitchenboy's Avatar
I heard the AAL will make for a stiffer ride, thats why I was trying to avoid that route. If I hauled heavy loads I would go that route.
Old Jul 4, 2012 | 06:58 PM
Custom leaf packs?? thats alot of money tho.
Cheaper route is stack blocks, but not the "safest." many people have done it with no issues
Old Jul 4, 2012 | 10:33 PM
kitchenboy's Avatar
Ive read that Rize makes a 6" lift block, but Im having trouble finding it. Sent an email to Rize, so I'll see what they say.
Old Jul 5, 2012 | 10:24 PM
kitchenboy's Avatar
Rize has a 6" block, but its not cheap. They have it flat and with a 1/2" taper. I was thinking about going with the taper to help with the drive angle.
Old Jul 5, 2012 | 11:31 PM
muddyfx4's Avatar
I have airbags in the rear. Lots of adjustment. You don't have to haul anything to have them......
Old Jul 6, 2012 | 10:39 AM
kitchenboy's Avatar
How do airbags install and whats the best brand. Is it like back in the day with air shocks where there a vlve in the back to fill them up. Whats the ride like also.
Old Jul 6, 2012 | 04:09 PM
Airbags are easy to install we have some on our F350s on the ranch...They mount ontop of the rear axle to the chassis...Firestone makes the best bags IMO...and I just ran airlines with valve stem looking fittings up through the fuel filler door..just put an airchuck on ur airhose that u use to fill ur tires and air them up check with a tire gauge...You can go all out with onboard compressors and gauges in the cab and stuff like that if you want but I just did it the cheap way...Took me about two hours and a six pack to install them...easy easy job and makes a WORLD of difference. As far as ride I couldn't really say because we do so much driving in the pastures and down dirt roads...Its a little stiffer on the highway but when the onetons are on the highway a trailer is usually hooked up...Never really paid attention when driving the one tons down the highway unloaded...
Old Jul 6, 2012 | 04:15 PM
Barrett's Avatar
Looks good!
Old Jul 7, 2012 | 01:28 PM
StoveTop's Avatar
I like my airbags and it allows me to raise the rear when needed. I have the RideRite system with a custom lift bracket but recommend the AirLift system with bag spacers. You need the spacers since you're lifted. My system works great and I like it, but I think the AirLift system looks cleaner.
I bought my system used so saved a ton of money...I am sure you find a used AirLift system out there. If not, they're still less than a new leaf pack.
Old Jul 7, 2012 | 06:51 PM
I would go with Stove's idea...I just went the cheap route because it was on a farm truck and don't really care how it looks...Just wanted something that worked....It doesn't look bad mind you but it just looks "simple" lol...
Old Jul 8, 2012 | 01:16 PM
kitchenboy's Avatar
Yeah Rize wants 290.00 for a 6" spacer. To me thats kind of a rip off. I told them I paid 130.00 for the 5" Rough Country blocks with ubolts, and they said there's is a little more, because they make it out of alluminum because of its size. A little more try over twice as much. If it was like 150.00 I probably would have ordered it already.
