Leveling kit not level!!
Just put some weight in the back to make it level and ride better :P, But being serious now, I have an 05 2wd and put on a 2'' Level Spacer and it was NOT level, so I Re-did suspension and went with Bilstien 5100 with 1'' setting and a 2'' spacer for 3'' and it sat too high in the front so I threw a 2.5'' block in the rear and ran with it! I like that better since I haul stuff and it becomes level with a Heavy load!
Are you sure you got a 2 inch kit? To my knowledge, Daystar only has the 2.5 and the 1 inch budget boost kits. I have the 2.5 on my 07 F150 2wd and it gave it perfectly level, at times front slightly higher looking. Then my dad has the 1 inch budget boost Daystar on his 2010 F150 Lariat 4x4 Crew Cab and it gave him the straight perfect level.. I dunno what you have on or what is done.. but to me I woulda guessed you had the 1 inch budget boost. My dads truck is similar and you can tell even with the 1 inch that it is higher in front, I couldnt imagine how much higher it would really be with a 2.5 inch installed, it would be way higher in front than in rear. Thats why I think you have the 1 inch possibly, did you order it or see it yourself to know for a fact?
Also running a combo of lift struts and spacers is not a good idea. People always look to push the lift limits without doing full lift procedures. 3 inch is too much IMO. I installed my 2.5 spacer and the change of angles installing back was a lil pain.. imaging those angles with anything else would be ridiculous.
Here is the kit they put on it or the kit they told me they put on it.
Http://wwwdaystarweb.com/productdeta...?productID=938
Do you mind getting a measurement off your dads for me just so I can tell? Thanks for your help
