Sponsored by: CARiD
Please help
Old Apr 1, 2012 | 03:01 PM
kamikid's Avatar
Please help
I recently installed a HellBent Steel leveling kit 2.5" and now i have a rattling everytime i go over any lil bump or anything. I believe it is my sway bar links that i need to change. Checked made sure all bolts were tight and that everything was correct. Checked everything and a few of my buddies who have installed kits said its probably the sway bar links. I was on jegs n summit racing and they have all different sizes which one would or should i buy, I got an 07 f150 xlt 4x4 4.6L
Any help be great thanks
Old Apr 1, 2012 | 09:08 PM
MossyOak3006's Avatar
Have you checked tie rod ends and upper/lower ball joints? All that can rattle similar to sway bar end links
Old Apr 2, 2012 | 07:16 AM
kamikid's Avatar
I am pretty sure its the links but havent checked them all. I was told most likely its the links on the truck so i figured replace those first then check the rod ends then after if those both are done the ball joint. Very unlikely it the ball joint i tested that seemed fine
Old Apr 2, 2012 | 08:45 AM
Is it right under your foot? I have been having that so I ordered new bushings and sway bar links to replace.
