Sponsored by: CARiD
Stack 2.5'' spacer with....
Old Apr 4, 2012 | 12:04 AM
  #61
MossyOak3006's Avatar
Originally Posted by 06yz250f
Mossy, If you have coil overs you don't need a leveling kit....
I had to get redesigned springs from Fabtech put on my coilovers. They're shorter than the original springs. I doubt I could tighten them up enough to get much lift. And honestly, after my huge coilover ordeal, I don't want to adjust them again. Here's the explaination to what happened to me: https://www.f150online.com/forums/su...er-owners.html
They're working fine now, so I don't want to mess with them
Old Apr 4, 2012 | 10:40 AM
  #62
Jaskdavis's Avatar
No way you are going to clear a 35 with wheel spacers on a 2wd truck.
Stop being cheap and just buy a 6" lift kit when funds allow it. You can pick one up for around $1100 if you are patient
I HAVE 34.5'' x 11 on my truck now, I didnt say I was getting 35'' 12.50'' on my truck? I am getting the same size I have on there but Mud Terrain instead of the All Terrains I currently have on there.
Old Apr 4, 2012 | 11:20 AM
  #63
pizzaman711's Avatar
Mud terrain even though same size on the sidewall will be a little bigger because of the more aggressive tread. So even though it's the same size it'll rub more.
And wheel spacers are just going to move your rubbing not get rid of it. So you rub on the frame now.. It'll stop that and instead you'll start rubbing the bumper and the inside of the fender, especially if you hit a bump when turning.
Old Apr 4, 2012 | 11:38 AM
  #64
06yz250f's Avatar
Did i say 12.50? no. if you are going to be a smart *** at least be a smart smart ***.
MT's have an aggressive side wall, most likely will have a wider foot print that the BFG AT which has a very narrow one.
Do what you want, just don't come here expecting sympathy when everything is fubar'd
Old Apr 4, 2012 | 12:29 PM
  #65
Jaskdavis's Avatar
Hahaha good one, smart smart ***! So uniballs are my best bet then I guess without spending more than $500? Sorry I thought 35''s were at least 12.50 wide? :o
Old Apr 4, 2012 | 01:18 PM
  #66
Why would all 35's be 12.50 wide? I've seen them range from somewhere around 10" to wider than your wheels are tall.
Just do it right, save your money and get a lift. Trying to piece this together and make it work, isn't going to work.
Old Apr 4, 2012 | 02:16 PM
  #67
x2 on not going cheap on the lift. I did it on my old truck, never doing it again. Constant nickle and dime stuff. Every couple months it was a tie rod end or sway bar link or ball joint or something
Old Apr 4, 2012 | 02:30 PM
  #68
Jaskdavis's Avatar
I never said "all" and **** all this, Im just goin to set my struts (if they EVER come in ) to 0" stock setting and put the rear block on and if I scrub at full lock then I wont turn to full lock! End thread and thanks for all the support, Dedication, and tireless efforts to a thread that lasted 5 pages when it shouldn't of Because my Dumbsmartass is stubborn!
Old Apr 4, 2012 | 02:41 PM
  #69
06yz250f's Avatar
your grammar needs
Old Apr 4, 2012 | 03:27 PM
  #70
Jaskdavis's Avatar
your grammar needs
How?
Old Apr 4, 2012 | 05:02 PM
  #71
06yz250f's Avatar
You just can't do anything on your own can you?
Tell your mom or gf (really any one who cares) that you need a new helmet as the one you are wearing now is too beat up and not doing it's job
How?
Old Apr 4, 2012 | 05:50 PM
  #72
Jaskdavis's Avatar
you just can't do anything on your own can you?
10-4, i done thawt me grammerz waz fine
Old Apr 4, 2012 | 06:30 PM
  #73
phattacorider's Avatar
Sooo...Who wants to see my 3 1/2 month old daughter giggling from getting raspberries? It's super cute! I promise!! LOL
Old Apr 5, 2012 | 12:34 PM
  #74
06yz250f's Avatar
Originally Posted by phattacorider
It's super cute!
I don't think the mother of the baby would be to happy to see you call it that
Old Apr 6, 2012 | 11:49 AM
  #75
97isnotold's Avatar
so did this guy fugg up his truck yet?
