Fab-Tech vs Pro-Comp 2wd Lifting, Pros and Cons...
3.5" lift spindles
Hey i ahve the fabtech 3.5" lift spindles and yeah they are 3 1/2 inches, there not the 3 inch ones. i like them alot. i don't really knwo the difference between the fabtech and procomp ones though. heres a pic of my truck , see if you like it or not
go to for more pics
www.f150world.com/4RDPWR
go to for more pics
Quality of Material
The spindles I got made the stock ones look like they came off a S-10. With the way companys are being sued these days do you really think a company would sell a weak front suspension part.I bought their spindles , control arms and rear hanger kit and would recommend them to anyone who wants to lift their truck and save a little money!
Re: 3.5" lift spindles
hey bro i was gonna put the 3 1/2" spindles on my 99 ex-cab 2wd and was just wondering how hard it was and did you use blocks in the back and what is the maximum size tires you can put on after the lift?
go to for more pics
go to for more pics
Originally posted by xdodgeguy
The truck looks really goo, which spindles did you end up going with? Also what did you do to the rear?
Well, I ordered Pro-comp spindles BUT the sales guy sent me Bulls-eye Spindles (go figure) and I installed 2.5 blocks in the rear. Also, I HAD to have cam bolts installed so the truck would align properly.
I just got back from ordering my spindles. I too got the bulls eye. The guy told me they make the best and you could incorporate other parts with them too, for example the upper arms if you ever want to go higher. Supposedly with Fabtech and some others you have to use only there parts in the future. Also he ordered only 1.5" blocks for the rear, he said that would make it level, but I see you have taller blocks on yours. Hmmmm, yours looks nice and level. Did you do the install yourself? If so how hard was it and how long did it take. Any problems?
Not any major problems installing except you need to order cam bolts for the front so your truck will align properly.
Also, DO NOT drive with the new tires to the alignment shop or you will mess them up BAD. I drove with my old tires/wheels while the new wheels were in the bed. BTW, the old (front) tires are worn uneven to hell after driving about 10 miles on them...
If have done suspension work before it should be a cake walk.
If not, just take your time and remember to replace the front shocks only AFTER you replace the spindles otherwise your f*cked.
For the back, you need to torque the u-bolts to 120-130 ft-lbs. MAKE SURE YOU USE A TORQUE WRENCH. If you already know all this-- sorry for posting if not, let me know if you need more info...
You, mention the shocks, I didnt think about that. Do you need to replace all of them? The front travel doesnt increase so I wouldnt see why I would have to do those but the rear however does increase. What did you end up putting on yours? Also what is the problem you mentioned with installing the front shocks?
