Decided i want to go prerunner style.
I just looked up the jd fab kit, for the price it only comes out to a couple hundred more than the dixon bros with the shocks. So I'd go with it if you have a little more to spend since it has the heims instead of ball joints (imagine never having to worry about replacing a ball joint again!). Also because it upgrades you to the porsche 930 cv axles which allow a little more travel especially if your using 4x4 at the same time.
Pizzaman711 gave you some good advice. I would stay away from foa shocks there is a reason they are cheap, saw a bumpstomp grenade under an F150. They are better suited for rock crawlers.
Also the Dixon kit is great and the owner does great work. I have their Ranger 4wd kit. And yes the JD Fab kit uses heims on the top of the spindle but it is a ball joint on the bottom mount and you get 930 CVs with the Dixon Kit.
Hope this helps...also you never mentioned what year or model F150 you have.
Sorry to bring up an old thread but I thougt you might need some help.
Addictive Desert Designs makes some great looking bumpers. Don't have any experience with them tho:
http://addictivedesertdesigns.com/sh...er-selections/
DO NOT BUY FROM THESE GUYS.
I know about 5 different employees that worked there. 1 still does, the others have left because its a joke and the owner is a tool. if anyone looks at this thread later and thinks they should try add, refrain from doing so. if people need a bumper or something similar built and are looking to buy something finished and bolt on, please either message me on this subject and I will either build you one myself, or point you in the right direction with the right information to good quality people who can give you a product that will look and actually be 100x better. ADD is bull****. do not use them for any reason.
NO NO NO NO NO NO NO NO NO NO !!!!!!!!!
