Decided i want to go prerunner style.
Dixon bro's sell's them, they just don't list them on their website but you could email them and try. Otherwise since you want it low profile you'll probably have to get it custom fabbed up. It's not hard to do if you can weld and do a little math, you just have to cycle the suspension to find the proper place to mount the shocks.
And, yes bumpstops are a must. Without those you'll overcompress the suspension and end up damaging something up front. In the rear without them you can end up breaking a leaf. And I'd go with the 2.5 bumps, matching them to the size of the shock seems to be a general rule. Just don't cheap out and get those poly bumps.
what do you recommend for rear bump stops?
Fox, King, Sway-a-Way, and FOA all make good bumpstops. FOA's are good if your on a budget and they'll definitely perform as well as you need them too. As far as I know you can only order them from their site though. And there lengths run a little weird, but they make coilovers and normal shocks too so you could use them all around and save a lot instead of going with fox's or kings's. Unless of course your buying them used. But most kits when they say what shock length you'll need are rated according to the way king's or fox's run so if you decide to go with FOA's you'll have to compare the lengths to get the right one.
I'm sure there's other brands out there, those are just the ones I can think of off the top of my head. Check polyperformance.com, they'll have a lot of stuff you'll need.
I just checked, the dixon bros ones are a pair of two for 500. The ones on poly are only a a single piece. And now that I'm thinking about it since you really won't be beating on the truck you could probably get by with 2.0's up front.
ok ill stick with the dixon bros kit, i emailed yesterday about a bed cage and rear shocks and deaver springs. i know they carry deaver springs but im located in canada so shipping could be a B-otch.
It'll all come on a pallet and be freight shipped so it shouldn't be horrible, but customs may be a pain. Just to give you a heads up its a whole lot cheaper if you get it shipped to a shipping terminal and pick it up from there instead of shipping it to your house. Here at least in the states it's like 200 for them to bring it your house because they need a truck with a lift gate to unload it.
Addictive Desert Designs makes some great looking bumpers. Don't have any experience with them tho:
http://addictivedesertdesigns.com/sh...er-selections/
Be careful with those rear bumpers, fiberglass bedsides tend to taper up at the back so those ones they have that look like oem replacements will hang down lower than the fiberglass where they meet each other.
looks like jd fab has a nice 4wd kit too. has king shocks and bump stops. which kit between dixon and jd would you go with. im not sure what kind of shocks the dixon bros have..
Dixon comes with fox's iirc correct. Pretty much same shock as king, just not as "flashy" I guess you could say. And for what you want, honestly I'd just go with whatevers cheaper unless your really planning on building a purpose built pre-runner.
ok so they are pretty much the same kit i think otherwise. the jd fab kit replaces the upper ball joint with a heim but the dixon bros still has ball joints
I just looked up the jd fab kit, for the price it only comes out to a couple hundred more than the dixon bros with the shocks. So I'd go with it if you have a little more to spend since it has the heims instead of ball joints (imagine never having to worry about replacing a ball joint again!). Also because it upgrades you to the porsche 930 cv axles which allow a little more travel especially if your using 4x4 at the same time.
