Sponsored by: CARiD
Need Help (Spindle issues)
Old Feb 13, 2012 | 09:59 PM
Socalkid3's Avatar
I recently bought a 2000 Ford 150xlt 2WD, 6inch fabtech lift, 3 inch body lift.
Driving it, all of a sudden my alignment was off, and my ABS brake light came on. i parked and noticed by hub cap was off and it didnt look good. I guess my spindle broke now im looking into a $1400 fix. new brake, pads, roter, and spindle.
(picture below is what broke.)
(Here is the front view.)
I just want anybodys opinon on what to do, Really wouldnt want to spend that kinda of money, but it happens. Thanks for reading, hope it helps, if not feel free to ask me questions!
Old Feb 14, 2012 | 02:55 AM
tbear853's Avatar
Looks like the wheel bearings got used up alot. Spindle didn't break though, but it might be toast now? Is the spindle all blued like? Might just need hub / rotor / caliper / ABS ring / .... and yeah, might as well get the spindle too. I'ld look at a salvage yaerd and see if I could get the parts as a group and maybe install new bearings when doing the swap?
Old Feb 14, 2012 | 11:35 AM
Buxton91's Avatar
If the spindle would've broke I think the tire would of went flying off. Looks like failed bearings to me. If there is an issue with the spindle itself, don't get junkyard parts. That's a fabtech spindle and you'll need to get a new one from them, but i highly doubt it failed.
Old Feb 15, 2012 | 05:19 AM
Socalkid3's Avatar
Tbear853 -
my machanic pretty much said that, the spindle got burned up, wish I didnt need a new one. But hes replacing all that stuff , bearings, hub, spindle, rotor, pad, brake, caliper, and ABS ring. Gotta call tomorrow to see if thats what hes doing. New bearings is a must through!
Buxton91-
i guess when the bearings broke it burned, did something to the spindle, sucks. But it was held on by the lock on the tire i think. And does it matter that it needs to be a fabtech spindle? I didnt even know!
Old Feb 15, 2012 | 08:43 AM
pizzaman711's Avatar
If it's a fabtech spindle on there then yes you need a fabtech spindle to replace with, otherwise the upper control arm won't bolt in correctly. Not only that but they add 3.5" of lift so if you throw an oem replacement on there your gonna be riding lopsided.
Old Feb 15, 2012 | 09:13 AM
when the bearings aren't maintained properly they can dry out and seize up. Then they will weld themselves to the spindle under the heat and pressure of the vehicle.
You should disassemble and check the drivers side as well. If they didnt grease the bearings enough when they put on the lift the drivers side could be about to fail too.
Old Feb 15, 2012 | 01:46 PM
Socalkid3's Avatar
Pizzaman -
oh I didnt know, and dont want that to happen. Hope,my machanic knows that!! If worse came to worse and it it was lobsided, can you fix that?
Patman - yes, I diffenetly am going to check the other side. Are you able to check yourself? So I can save myself a machanic stop?
Old Feb 15, 2012 | 02:04 PM
If it ends up with a oem spindle on one side and lift one on the other, the only fix would be to call fabtech and hope they'll sell you an individual spindle or put an oem on the other undamaged side and lower it down. If you have more than 5" of lift then theres a very high chance you have lift spindles.
Old Feb 15, 2012 | 02:25 PM
Socalkid3's Avatar
Originally Posted by pizzaman711
If it ends up with a oem spindle on one side and lift one on the other, the only fix would be to call fabtech and hope they'll sell you an individual spindle or put an oem on the other undamaged side and lower it down. If you have more than 5" of lift then theres a very high% chance you have lift spindles.
Oem? and so my truck could get lowered? And its a 6" lift, so I think ill need if its not fabtech.
Im new to the world of lifted trucks, always wanted one. Now I got one with issues haha
Old Feb 15, 2012 | 02:53 PM
06yz250f's Avatar
oem = factory parts.
You have to order a new spindle from fabtech if yours is damaged.
Old Feb 15, 2012 | 02:57 PM
Yup your gonna have to call up fabtech and order a new one because you can't buy them individually online.
Old Feb 15, 2012 | 03:32 PM
Socalkid3's Avatar
Okay, ill make a call. Thanks you guys.
Now can you grease up the bearings yourself? Would I only do it the left side? Or all sides?
Old Feb 15, 2012 | 03:42 PM
DenoFL's Avatar
https://www.f150online.com/forums/pa...on-bars-4.html
LOL
Old Feb 15, 2012 | 04:00 PM
He only needs one spindle, not a whole kit. And I doubt he'd split that considering it would make a real pain to sell haha.
Old Feb 15, 2012 | 04:34 PM
Socalkid3's Avatar
Yeahh noo lol no kit, just one spindle. Having hard enough trouble selling a go kart. I think a kit, exspecially where I live would not be possible lol
