Sponsored by: CARiD
6" Suspension Lift
Old Jan 23, 2012 | 01:26 PM
  #31
07F150Lifted's Avatar
Can I Fit 18X9 Wheels With 35X12.5 Tires With A 6" Rough Country Suspension Lift Or Will They Rub The Wheel Well At Full Turn?
Old Jan 23, 2012 | 02:02 PM
  #32
06yz250f's Avatar
whats the backspacing on the wheels... run whats recommended from the lift manufacturer and you will be fine.
Old Jan 23, 2012 | 04:35 PM
  #33
There 5 inch Backspacing But I was just wondering will they rub I've seen a lot of trucks I here with an additional 2" or 2.5" level kit on top of 6" spacer I was just wondering if that was only preference look or if it would really help I want a level 6" lift on my truck so if I don't need the level kit on top of the spacer that is all I was wondering thanks
Old Jan 23, 2012 | 05:20 PM
  #34
06yz250f's Avatar
the 2 or 2.5" extra spacer is to run 37's.
If you were running a 12" wide wheel maybe a level on top to prevent rubbing, but you will be fine. stick to specs recommended and tire size and At most you will have a very minor rub depending on your tire choice.
Old Jan 23, 2012 | 07:40 PM
  #35
I Want 18X9 KMC XD Rockstars And 35X12.5X18 Nitto Trail Grapplers does anyone have this combination set up on a 04-08 F150 any problems with rub with a 6" Rough Country Lift?
Old Jan 23, 2012 | 08:24 PM
  #36
savage land's Avatar
[bc
Old Jan 23, 2012 | 10:24 PM
  #37
Thanks For The Picture Your Truck Looks Great! That's what I'm looking for with my truck I'm not a big fan of a level and 6" lift in the front I like the 6" all around level with 35" tires so it sits level and it's a great height
Old Jan 24, 2012 | 06:50 PM
  #38
Old Jan 24, 2012 | 06:51 PM
  #39
Old Jan 27, 2012 | 10:40 PM
  #40
Does anyone have a 6" Suspension Lift along with an AAL in the rear so the rear is 2" or more higher? With pics?
