Sponsored by: CARiD
01 2wd 2" level shocks
Old Dec 20, 2011 | 12:40 PM
spencer95's Avatar
Hey I'm planning on installing some 2"coil spacers. I was just wondering what kind of shocks I should get. I know its not necessary but I need new ones anyways and I want some longer ones so the rides not to rough. I've been looking at procomp ones but I dont know which ones to get like what model number since it doesnt say anything about how much lift.
Old Dec 20, 2011 | 12:59 PM
pizzaman711's Avatar
Find out how long the extended and collapsed length is for your factory one and add about 1.5" to both specs give or take a little.
Old Dec 20, 2011 | 01:04 PM
spencer95's Avatar
alright thanks il check it out after work
Old Dec 20, 2011 | 10:58 PM
spencer95's Avatar
Alright so this one should be right I think. http://www.procompusa.com/prodDetail...3306&plID=1819
I was wondering about the mounting. It doesnt say if it the top is stem mount? And for the bottom mount does the plate thing where it bolts swap over from the stock shock? sorry for the noob questions
Old Dec 20, 2011 | 11:19 PM
lltoolj's Avatar
are you getting just the fronts? you need the shocks with the stem at the end (top)that sticks through the hole then the nut goes ontop. not the ones with the round at the top like the one in the link. the bottom will need the round then yes your stock hardware will be used on the new ones
Old Dec 20, 2011 | 11:42 PM
spencer95's Avatar
Yea just the fronts for now. Im just gunna go with rough country shocks then since they make it nice an easy with a chart for noobs like me.
Old Dec 20, 2011 | 11:50 PM
Yup you need stem top and the flat plate style bottom.
