Sponsored by: CARiD
need some pics and help deciding on lift?
Old Dec 26, 2011 | 08:27 PM
Jughed's Avatar
If you take the wheel to fender gap being equal your truck wont be level. The body line is an equal distance from the bottom of the truck all the way across. If that body line is level you truck is level. Your tires and wheels should be the same size and distance from the ground. If you use that as a reference and compare that to the body line that will tell you if your level. I added some lines to show the difference.
Nitroxs pic is pretty straight on sow its easy to show. the 2 white lines are level and referenced from the top of the wheel and tire. The red line is an exension of the body line. The fender gaps are pretty close to the same distance. The front fender on our trucks is taller than the rear.
Smokeys truck green lines show the wheel and tire height. Red is the body line and the white is the fender gap. I did KRs too but the pic isnt straight so it isnt as clear. But you can see the difference between the 2 setups. Smokeys is a more of a Bulldog or "Cali-style" Nitrox has a small amount of rake. The only thing consistent is that everyones truck is a little different and the effects of the same kit may be different on 2 different trucks.
Old Dec 27, 2011 | 04:32 AM
KingRanch4Life's Avatar
Originally Posted by Jughed
If thats level someone needs to straighten their house.
You must be unfamiliar with basements... My driveway slopes at the end(where my truck is parked) to account for the basement... So the truck is actually pointing down hill... Disregard the house in the background....
Old Dec 27, 2011 | 08:48 PM
04onefifty's Avatar
Originally Posted by KingRanch4Life
I have the auto spring 2.5 in the front and 3" blocks in the rear with 35's... Sits pretty level to me...
WOW! thats a sick truck man. wish mine looked like that! that 3" in the rear and 2.5 up front looks good on your truck
Old Dec 27, 2011 | 09:01 PM
Big_Smokey's Avatar
Originally Posted by 04onefifty
that truck looks awesome with just a 3" level!! love that color! any problems with the front end? i know my truck needs new ball joints so ill probably get them done at the same time.
Traded the truck at 75000+- miles. kit was on for most of it. No i never had a single problem with it. Well, i did have to replace one of the boots that covers the front 4wd....but that was it warranty work. I dont think that was from my leveling kit i think i may have ran over something..i didnt offroad, but it was a hunting/fishing/construction site truck.
Also as stated above my truck is bulldogging a little bit. I dont have any pics after i installed the Long Add a leaf. then i had about an inch of rake, which is what i wanted for hauling and towing, not to mention getting rid of the spongy rear end that i feel these truck have.
Old Dec 27, 2011 | 10:05 PM
Jughed's Avatar
Silly angles, do me a favor. Park it in your garage, provided it doesnt have 4inches of fall for drainage. And measure from the ground to the body line in front the rear tire. Then measure from the ground to the same body line behind the front tire. Then measure from the ground at the center of each tire to the bottom of the fender, front and rear. Let me know what you get.
nice wheels.
Old Dec 27, 2011 | 10:39 PM
lltoolj's Avatar
Would you like some turkey with that stuffing
Old Dec 27, 2011 | 11:11 PM
Jughed's Avatar
they fit, therefor i shall
Old Dec 28, 2011 | 12:36 AM
lltoolj's Avatar
Is it your truck?
Old Dec 28, 2011 | 08:00 AM
Jughed's Avatar
nope not mine, wouldnt even consider trying that. You could probably run 44s on yours though if you wanted.
Again to the OP, use a tape measure, basic math and common sense. Measure how much lift you want and order that height to achieve the look you want. There are several different interpretations of what level is, and every truck is different. You really cant say because this guy used this in front and this in back my truck will look the same. 2004s have more factory rake than 2008s. When KR4 says he put 3 inch blocks in the rear im assuming he removed the stock blocks. My point with the pics, is perspective can be deceiving and take measurements on your setup. Just trying to help you make an informed decision, as GI Joe said "knowing is half the battle"
Old Dec 30, 2011 | 11:49 PM
nice wheels.
Will do... Currently away from home working.... Will get to it when I get back...
Old Dec 30, 2011 | 11:52 PM
Stuffing?? I'm stuffed with wheels and you're light on 4X4....
Old Dec 31, 2011 | 12:10 PM
philly164's Avatar
nice trucks!!
Old Jan 4, 2012 | 11:33 PM
mrhoopes's Avatar
don't know how too get a picture in here but my truck has a 3-1/2 level with a 3 block in rear. picture in my profile. I clear 35x12.5 with no rubbing on stock wheels.
Old Jan 6, 2012 | 01:35 AM
04onefifty's Avatar
i love the stuffing look. to me it looks mean or something. cant think of a word for it... if it fits why not haha
Old Jan 12, 2012 | 12:13 PM
mrhoopes's Avatar
