Sponsored by: CARiD
Leaf Springs Question
Old Oct 21, 2011 | 07:10 PM
Cellside's Avatar
Exclamation Leaf Springs Question
Hey Guys,Can Anyone point me in the direction of how to on how to remove leaf springs on 2006 F150 Screw,I'm planning on installing Eibach's 2/4 pro truck kit with the shocks and need some help on the proper way to remove things,don't want to seriously mess something up.
Any help is greatly appreciated.
Old Oct 21, 2011 | 09:01 PM
Cellside's Avatar
Bump
Old Oct 21, 2011 | 09:13 PM
jack the truck up until the axle hangs loose, then support the truck on stands, then unbolt stuff.
on your specific truck the drivers hanger bolt (front leaf bolt) will be a PITA you either have to temporarily remove the gas tank or cut the bolt in half.
If you wanted to make a trip east i could give you a hand with it, but you arent exactly right up the street from me
And BTW most of us lowered guys hang out down in "street scene" section
Old Oct 21, 2011 | 09:23 PM
Cellside's Avatar
Aw man that does sound like a major PITA,not very fond of removing the gas tank or cutting bolts,but lets say i do decide to cut the bolts...should the drop kit come with replacement bolts or do i have to go hunting for some in junkyard?
And thanks for the offer Pat,I live near Houston,not sure where your located.
Old Oct 22, 2011 | 04:19 PM
Cellside's Avatar
Bump anyone?
Old Oct 23, 2011 | 08:24 AM
im up in Dallas area.
No you'd have to get a new bolt, preferably from Ford. I want to say they're like 20 bucks a pop
Old Oct 23, 2011 | 09:46 AM
oleman48's Avatar
Jus t did mine last month,bolt from Tasca $6.05 + $10.00 UPS.The secret to cutting bolt ,use sazall w/ new quality blade. Use cutting oil on the blade & medium speed on saw.Caution around gas tank.
Old Oct 23, 2011 | 01:14 PM
Cellside's Avatar
Thanks oleman48 for the info,should be a bit easier with this,I was thinking of cutting it with a grinder but that will cause a lot sparks which is bad,I'll just go out and buy me a sawzall and blade while buying the rest of tools needed
Old Oct 25, 2011 | 06:43 PM
T_S_S's Avatar
Former Sponsor
4" leafs ride like crap. Why not do a 5" flip kit and do a 3" drop in the front?
http://belltech-store.com/aca_php/im...mages/6440.pdf
Old Oct 25, 2011 | 09:50 PM
no flip kits ride bad, they bottom out really quickly, and promote axle wrap. I stay away from flip kits if at all possible
Old Oct 25, 2011 | 10:03 PM
tbear853's Avatar
Thumbs up
Get a good one, you'll find uses for it you never thought about. I resisted for years, finally bought a Porter Cable 110v HD one and liked it so well, bought a 18 VDC Cordless DeWalt Combo with drill and sawsall. Buy a good one and at your age, it'll return it's worth several times over.
For steel cutting, I favor bimetal blades, 14 or 16 tpi.
Old Oct 25, 2011 | 10:08 PM
I just picked up a Dewalt Sawzall at Sears a couple weeks ago for under 100 bucks on sale (same one we use at work and we beat it up at work)
Old Oct 26, 2011 | 12:06 AM
tbear853's Avatar
Sears is where my Porter Cable came from .... it's where probably 70-80% of my tool buying over the last 40 years has been done .... I like Sears.
Old Dec 1, 2011 | 03:45 PM
Cellside's Avatar
Thanks for the info guys
Old Dec 2, 2011 | 03:32 AM
tbear853's Avatar
Did you get her done?
