Sponsored by: CARiD
thinking about goin up to 40s !, need help
Old Oct 9, 2011 | 07:12 PM
backwoodsboy70's Avatar
im thinking about goin up to 40's on my truck, i have 37s now and they look small imo, i have 6+3 body and coilovers cranked 2 inches , will 40x15.50's on 20' hostages fit ? will they rub way to bad , and should i rase the rear with a 2inch leaf ? or will it be just fine, and im gonna go 4.88 gears will they be enough for 40's on 20's?
jus looking for sum advice , since therss a few ppl on here with that set up , thanks yall , any help greatly apprecitated
Old Oct 9, 2011 | 07:22 PM
06yz250f's Avatar
i'd go with a narrower 40, probably will have to trim a little as well depending on wheel and tire choice
edit: yes raise the rear up
Old Oct 9, 2011 | 07:50 PM
pizzaman711's Avatar
If the picture in your sig is the way it sits now definitely raise the rear up some. With 40's in the back and the way it is now I see it bottoming out into the bottom of the bedsides all the time, so 2" would definitely help.
Old Oct 9, 2011 | 09:16 PM
atr04screw's Avatar
They should fit fine, but you should probably raise the rear up with either an add a leaf or lift shackles. dilloncawthon has 41x14.50s on his truck with a 6+3 and a leveling kit and I think the only problem he had was rubbing in the rear.
Old Oct 9, 2011 | 10:10 PM
noregrets's Avatar
Do it but lift the *** end first, should look sweet.
Old Oct 9, 2011 | 10:56 PM
dilloncawthon's Avatar
yeah my next tire is going to be a 40x15.50. like atr04screw said, my main problem was the rear tires scrubbing. i think a 38in. tire is the biggest that can fit in the wheel well so that was the cause.
oh and if you haven't re-geared yet 4.88's will be perfect for that set up. i can hold the brake and when i hit the throttle my back tires almost immediatly start spinning.
the only thing you should watch is the width of the wheels. i know fuel makes some wide wheels with low backspacing so that could cause a problem.
Old Oct 10, 2011 | 06:31 AM
Thanks for the info guys, sounds like 4.88 is plenty then, and for the wheels i have to find the backspacing out, if i dont do fuels im dooin rockstars
Old Oct 10, 2011 | 11:05 AM
fx4 for life 79's Avatar
I'm going to run 40x14.5 km2s for my next set
Old Oct 13, 2011 | 07:12 PM
03fx4driver's Avatar
Add-a-leaf the *** end. Front should be plenty clear (may have to trim lower bumper). I wouldn't go wider than a 40X13.50 without some kind of wheel spacer or a 10" wide wheel with at least -25 offset. Gears: 5.13's all the way--yukon makes them for the 9.75 rear end, you just have to grind that center pin down to get it by the ring gear---I did it on my 02 and it works like a champ. Expect a front end shimmy and quick wear on tie rods and ball joints!
Old Oct 13, 2011 | 07:17 PM
06yz250f's Avatar
and then how do you get the front done?
Old Oct 13, 2011 | 07:42 PM
I didn't have any problems with that pin. If I remember right there was one part that I had to replace in a different order from removal but I don't remember what it was lol. Everyone makes 5.13's for the 8.8 front and rear but Yukon is the only one I found that makes them for the 9.75 rear.
Old Oct 19, 2011 | 02:25 AM
if i remember correctly the problem with 5.13's was nobody made them for the front reverse cut and you had to get a set custom made.
Old Oct 19, 2011 | 11:39 AM
Buxton91's Avatar
I thought you were trying to sell this beast? haha
Old Oct 19, 2011 | 07:33 PM
When I was in the market for 5.13's it seemed like almost everyone had them for the 8.8 IFS. I had to HUNT for the 9.75 R&P. Finally found them at Ron's Machine Shop on eBay from Yukon.
Old Oct 21, 2011 | 01:22 PM
i been tryin to sell this thing for 2 yrs but no one wants to pay anything for it it kbb at 17500 , im askin 17 veryyyy very fair for how nice it is , evryone is cheap and useless and jerks me around , so i might as well go bigger lol
