Sponsored by: CARiD
Anything else to replace while doing shocks?
Old Aug 31, 2011 | 09:35 AM
racerx1307's Avatar
Could use 2 or 3 cents worth of advice. My 2005 Screw (5.4 4x4, stock height) hit 94,000 miles. The ride isn’t so great anymore and since I plan to keep the truck I’m looking to clean up the ride. I replaced the ball joints a few months back with Moog’s. I’ll be picking up some new shocks soon, leaning towards the Bilstein 4600’s. Where I need some maint. advice tips. While the front is apart replacing the shocks are there some easy and/or other components I should look to replace. I’ve seen bushing kits, steering rods, sway bars, etc… It’s a daily driver, no off road, normal loads in back.
Thanks for the help...
Old Aug 31, 2011 | 11:03 AM
Scooterdog's Avatar
Replacing the Front Struts
Were the upper control arms part of the "ball joint" replacement? If not, it's easier to do them while the struts are out. Don't forget the aliment and keeping your tires balanced is the best way to keep the front end parts healthy.
Old Aug 31, 2011 | 01:37 PM
StoveTop's Avatar
Good to hear you already did your BJs. If I were taking my front end apart, I would consider doing brakes and checking wheel bearings. For shocks, consider the adjustable Rancho 9000xls, but anything would be better than old OEM shocks!
Old Aug 31, 2011 | 02:05 PM
canadianelbow's Avatar
Have you replaced the stock spark plugs yet?
Old Aug 31, 2011 | 04:18 PM
racerx1307's Avatar
Scooterdog – No just the lower BJ’s were done. It will be going in for an aliment once everything is done. How expensive is the upper part?
StoveTop – Brakes are in good order, fairly new still about ½ left. I’ll check the wheel bearings thanks.
Canadianelbow – Yes, did the plugs the same time I did the ball joints. Just had the transmission fluid flushed and replaced as well.
Old Aug 31, 2011 | 08:03 PM
In the world of preventative maintenance, what about the fluid in your rear diff? A hundred thousand miles should be beyond a fair life expectancy. At some point everything breaks down. Same is to be expected of brake fluid, steering fluids, ect. What about fuel filters?
