2001 F150 Supercrew...need 3 inch rear block!
Alright, i got 2 Procomp ES3000's for the back, not sure what shocks ill get for the front yet. Idk whether to get 0-1 inch lift shocks or 3-4 inch lift shocks. those are the only two available but i need a 1.5 inch lift shock. any light shed on this would be great, i figure id go with the 0 - 1 inch so i know hat theyll fit when compressed, they just may not be long enough when off-roading which i dont really do that much. and a 3 - 4 inch lift shock may not even fit when compressed under full load.
anyways, just got my 1.5 inch daystar spacers in the mail, and just ordered 3.5 inch doetsch spindles that should be here next week. the 3 inch blocks are going to take awhile, 4wheelparts was out of stock so they had to order them, said itd be like two weeks. thats the update, help with the front shocks would be great!
ive got a 4in block set with U-bolts and front shocks, they will work with what you got. if you want them. PM me.
and just my .02, instead of getting the spacer you should have got the 2in lift coil from rough country, that with the 3.5in spindles and a 4in block would make you perfectly level.
not too interested in used shocks, and i already have the spacer so im not going back now lol. ive seen plenty o f150s with this set up and ill be perfectly satisfied with it. thanks for the suggestion tho!
