Sponsored by: CARiD
Will these tires fit/rub? I know, I know...
Old Aug 12, 2011 | 09:45 AM
vtjenkins's Avatar
After much searching, several days, I couldn't find any threads that answered my question.
I'm going to level out my truck later this fall and want a 2" kit up front (either an Autospring spacer or the Rancho Quicklifts with mathcing 9000xl's in the rear) w/ 1.5" AALs in the back. I'm gonna put on some 275/65 r-20 Toyo MTs, which are appx. equivalent to 34x11's. I also have factory 20x8.5 rims. Will these rub?
Thanks in advance...
Old Aug 12, 2011 | 10:34 AM
06yz250f's Avatar
you have stock wheels, and you could not find the answer after searching for several days
and just so i don't have to answer this stupid over asked question right away, are you 2 or 4wd? need to know before a correct answer is given.
Old Aug 12, 2011 | 04:03 PM
vtjenkins's Avatar
4x4...
tough guy on the computer i see...u guys crack me up with your posts...
hell, if you can find a post where someone looking to see of 34x11's will fit their factory 20s, then let me know...pretty rare question...
and i read your write up by the way that starts off with 2.5", which i don't care for...
Old Aug 12, 2011 | 04:12 PM
06yz250f's Avatar
edited the write up just for you.
common sense says if you can fit a 35/1250 on a stock wheel with a 2.5" kit you can probably fit a smaller tire with .5" less lift.
and your question has been posted dozens of times but because you couldn't comprehend a simple search button you didn't find it. i can't even imagine how you operate google.
nassty has the exact set up you want on his 2011. 2" leveling kit and 295/60/20 (IIRC) which is a 34/11/20. so it's not "rare"
Old Aug 12, 2011 | 04:30 PM
vtjenkins's Avatar
oh man....u crack me up...
thanks, i guess...hahahaha
