Procomp 5.5" Blocks on 06 4x4
I have asked this before but here goes again. Any issues with the pinion angle using the procomp 5.5" Blocks, axle wrap etc??? Are they tapered??? I have a 06 4x4....
Lift blocks for f-150s can't be tapered because there are 2 center pin bolts going through the leaf spring pack instead of the usual 1 on other vehicles. If the block was tapered, the heads of the center pin bolts wouldn't line up correctly with the corresponding holes in the top of the blocks.
And I agree, don't stack blocks if you can avoid it. It's just another variable that can cause problems. And it could be a pretty serious problem if the blocks separated while you were driving
I doubt they are. My 5" Fabtech blocks are not tapered
I spoke with the rep from Pro-comp directly, not 4wheelparts and he said that the block is tapered about 1/8" overall. Not much at all but that is what I am being told. I will measure and post when they get here but that is what the rep said....
The fabtech blocks are not tapered, you are correct, I installed helped install that kit on my neighbors truck, they measure the same front and back. I am not trying to get into a pissing contest believe me, just relaying what I am being told about the procomp blocks. I will post my findings when they arrive...
Very nice truck though...I was going to buy those tires. I here they are great offroad but do not really have that great of road manners...What do you think???
I thought they wouldn't be that great on the road, but they are fine. They have pretty loud tire roar, but I like it. They don't pull or shake or anything. I'm pretty impressed by their road manners.
