just installed upper control arm and have a ?
I just installed new moog upper control arms, and outer tie rod ends, and struts. After I got everything back together I put the greese zerks in and one of the upper control arms was missing the zerk and cotter pin. I checked the thred of the other greese zerk and it was a 1/4X28 so I bought a pack of zerks and guess what it dosen't thred in to the ball joint. I can't tell if there are any threads there or not. Would my best bet is get a bottom tap and rethread. I have a thres thread but that won't work it bottoms out. I would go in and complain about this but I don' want to take it all apart because of one zerk. Anyone ever have this, and what did you do to fix it?
I don't beleive the BJ's are threaded for the Zerks. There is a hole in the BJ and the zerk threads itself in, self tapper style. I just replaced my UCA's and lower BJ's, all with Moogs and that is how they were. Either way, you got it done.
That's how I remember it as well...no tapping req'd. Forget the the advice to remove the UCA for the zerk, that's just silly. Pop a larger threaded zerk on there, fill it with grease and don't worry about it for a long time.
