Need Help ASAP 4X2 wheel bearing
Have this grinding on the front driver side ( sounds like mudders when you swerve back and forth at 40 mph) for a week now and I thought it would be a ball joint. But more and more reading looks like a wheel bearing . I am affaid it will fail on the road. I replaced the hubs and pads ( thermo quiets) a year ago and there is still alot of pad left, can I just pick up the hub and used the same pads? Plan on getting everything from NAPA. If they have the spindle nut that too will get replace. Now hopefully harbor freight has the torque wrench
Any tips or tricks???
That is definitely your bearing, I had the same issue. The rotors come with the wheel bearing already pressed in. (stupidest idea ever). If i were you i'd replace the new rotors (with the bearing assembly) pressed in already and new pads again. Also replace the spindle nut as well the rubber eventually wears out. check rockauto.com - i got those parts on there for cheap... make sure you torque the spindle nut to spec (i dont remember exactly what it was either - google)
Good Luck!
Good Luck!
