Sponsored by: CARiD
Next options??
Old Jan 17, 2011 | 03:41 PM
jdt_ellinor's Avatar
Next options??
I have the 2wd 01 ext cab 4.2L
Its lifted 6.5/5
I have a 3" PA body lift on.
3.5" springtech spindle up front and 2" block on the back
What other options do i have for another lift (mainly up front i can get the back lift easily)? size doesnt matter.
I know of the 1-2.5" coil spring spacers.
2" taller coil springs
3" taller coil springs with new upper a-arms. But with the coil springs idk if its an actual 2-3" lift, because after you out them on the weight of the truck would compress them some. correct?
Old Jan 17, 2011 | 09:33 PM
wandell's Avatar
Basically you can install lifted coils or coilspring spacers (but don't combine the two) or install a full suspension lift.
