Sponsored by: CARiD
rough country alignment issue
Old Dec 14, 2010 | 02:29 PM
Wade06XLT's Avatar
I'll attach pics later, but on my '06 I had their lift, did some beating and banging off road. No problems whatsoever.
Old Dec 14, 2010 | 08:57 PM
Jcaz07's Avatar
I dont know if the problem is only with rcx i have a 4inch rancho on my 07 and it's doing the same thing
Old Dec 14, 2010 | 10:22 PM
pat28's Avatar
Do you have the old kit or the new one? And if you have the old one do you have camber/caster bolts? If so, those parts are the reason why your alignment stays true... otherwise you are one lucky "!/% !! Because mine keep getting knock off but I just added tabs and camber/caster bolts so it can withstand some more abuse.
Old Dec 15, 2010 | 07:13 AM
bossman15's Avatar
Are camber/caster bolts universal and available at an alignment shop? I'd like to get it done while my brother is getting his alignment done tomorrow
Old Dec 15, 2010 | 07:38 AM
pat28's Avatar
No they are not. But most bolts kit are in stock in larger parts retailer specially for the f150 since it's a big seller in the states. Otherwise refer to post #13 I already gave you a place where you could get them.
Old Jan 6, 2011 | 07:28 PM
azmidget91's Avatar
Originally Posted by pat28
They wanted to produce the cheapest 6'' lift kit. By cheapest I mean low cost. Not bad quality. They succeeded but left some quality on the table.
Go to rockauto.com and look for part#K80087 it's 34.79$.
do you have to buy 2 of those kits? or does it come with all 4 bolts?
Old Jan 9, 2011 | 11:01 AM
pat28's Avatar
You have to buy two of those kits.
Old Feb 8, 2011 | 01:20 AM
LilGoomba7's Avatar
looking at the insallation instructions on the rough country site.. it says the kit comes with 4 cam bolts
Old Feb 8, 2011 | 07:21 AM
bossman15's Avatar
Mine from ntwonline.com did not.
Old Apr 13, 2011 | 03:52 PM
Lariat10's Avatar
I'm having the rough country level kit installed tomorrow on my 2010 F150 and a buddy of mine had to install different camber bolts on his 2009. Should I look into changing out my camber bolts? I called the shop today and told him I've heard this issue exists and he said "I assure you that it will be fine, I haven't had anyone come back to me complaining about uneven wear yet." Thanks in advance.
Old Apr 14, 2011 | 11:41 PM
bossman15's Avatar
Wouldn't worry about it with a level.
Old Apr 22, 2011 | 11:52 PM
wingman4's Avatar
Yeah, you will be fine with a level kit. At least with the camber bolts. You won't have to change that out with just a level kit. The full suspension lift they have makes you replace a lot of suspension components up front, which apparently on the older lifts replaced the OEM camber bolts with regular bolts(?). But with a level kit you will be fine in regards to your camber bolts. My brother had some trouble with his RCX level kit in getting it actually aligned right... He kept wearing his tires uneven. Got that issue fixed now tho
Old May 3, 2021 | 09:19 AM
Jody4352's Avatar
Adding stoppers to LCA
@Bossman newer RCX lift kits are known to be easily knocked out of alignment. Some will never have isues and some (like me and like you) are having the hardest time keeping it aligned. you have three options :
1. Add stoppers like I said earlier and put some camber/caster bolts on.
2. Keep going for an alignment each month.
3. Return to stock or and buy another lift.
As far as I'm concern #1 makes the most sense out of the three.
pat28 can you give more detail on adding stoppers to the LCA
