Sponsored by: CARiD
04 Front End Rattle, Help plz
Old Dec 11, 2010 | 05:37 AM
password's Avatar
When my truck (04 Lariat Crew) goes over any slight bump or variation in the road I get a rattle that sounds like re-bar bouncing around. I have hunted for it profusly and have found not a darn thing. I'm not sure if the load on the suspension is hiding it from me or what. It only happens when its cold out side and there is no vibration only the noise. I have defeated the IWE beast so thats not it, checked over the control arms upper and lower when replacing my hubs (due to 4x4 not working in the snow...but thats another story). Iam at a loss. and of course we are finishing out a parking deck right now and it just echos like a friggin train horn through that thing. I cant recreate the noise jumping around on the truck, I have climed all though the undercairrage banging and shaking everything I can get my hands on. and now I ask you....Help.
Old Dec 12, 2010 | 01:25 PM
password's Avatar
wow, crickets....
Old Dec 13, 2010 | 01:23 AM
fatty4x4's Avatar
Have you grabbed your strut or shock and given them a twist? My rear shock bushing is worn and causes a metal banging/clanging noise that sounds like it is coming from the front. Worth a look..
Old Dec 13, 2010 | 10:53 AM
password's Avatar
Wink
i'll give that a whirl, found another thread on here that suggested a hoist bracket going to give that one a try today. in searching around the net I've found that there are alot of people having this issue true it could be a multitude of things but it is also happening on brand new trucks 09-10 raptors, lariats, fx4's, ect... I would be furious if I spent close to 50K on a truck and then it rattled like my 04. especially a raptor that was modled off of a friggin cup truck.. im hoping that mine is the bracket, that would be bleeping sweet
Old Dec 13, 2010 | 05:43 PM
bossman15's Avatar
Wow mine is doing the exact same thing and I put my lift on a few weeks ago and thought something didnt get put on right! If you figure out what it is please let me know as I have checked everything I could grab as well. Sounds like mine is coming from the left side.
Old Dec 17, 2010 | 07:22 PM
huntnfish308's Avatar
My truck is also making that exact same noise. I'm going to take a look and see if I can figure it out tomorrow. I noticed it started last week and it's getting worse. It is the most noticeable when I'm going slow over bumps. I can hear the noise as well as feel it in the floor and steering wheel.
Old Dec 18, 2010 | 01:00 AM
bossman15's Avatar
No luck in locating, OP?
Old Dec 18, 2010 | 09:57 AM
No luck here.
Old Dec 18, 2010 | 12:48 PM
MuddYMesS's Avatar
check brake components, shocks, hubs, steering linkage, control arms, and maybe check to see that the front diff in all torque down
Old Dec 18, 2010 | 01:58 PM
jmt0645's Avatar
check your REAR shocks, upper and lower mounting bolts for proper torque. I'll bet there loose, mine would keep working loose ( only lost ~4lb-ft from torque spec) and would rattle like crazy till i put some locktite on them and retorqued.
Old Dec 18, 2010 | 03:31 PM
beechkid's Avatar
25 Year Member
check sway bay end link (with & without load), shocks, exhaust mounts, fuel line mounts
Old Dec 18, 2010 | 06:19 PM
bossman15's Avatar
It is definitely from the front
I think I'm just gonna have to retorque everything
Old Dec 21, 2010 | 06:57 PM
I found the problem with my truck, the cv axle. I found it by having someone rock the truck back and forth while standing on the running board as I'm listening underneath. I also noticed grease all around the area from a rip in the boot. With the moisture getting in and the grease coming out and the sound I heard I'm sure this is the issue.
Old Dec 23, 2010 | 06:34 PM
aceford's Avatar
i have the same problem with my 2003 f150 supercrew 4x2. ive grabbed everything underneath as well. nothings loose...must just be a ford thing.;0.
Old Dec 25, 2010 | 12:42 AM
fordmatt21's Avatar
I'm having the same problem it seems. Got a knock coming from the front left side of the truck over small bumps and cracks, I can feel it right under my left foot. Got under the truck yesterday and everything is tight, nothing broken. Control arms, ball joints, tie rods and endlinks have all been done in the last 3k miles.
Any one else solve this?
