Sponsored by: CARiD
Rear lift blocks??
Old Nov 10, 2010 | 09:33 AM
Stevo2396's Avatar
Rear lift blocks??
I am installing a rear lift block kit to raise the truck up another 2" to get my rake back. I was just wondering if the original shock will still work or should I purchase a new set for the added 2"?
Old Nov 18, 2010 | 07:46 AM
Joseph_73's Avatar
I did the exact thing that you are thinking about.. never changed the shocks out.. its been over 3 years and no problems.. Hope this helps.
Old Nov 18, 2010 | 08:38 AM
DarkShadowSTX's Avatar
You should be fine with the original shock. I replaced my shocks though when I put in my rear 3" blocks, only because the shocks came with everything else that I bought from another member. The shocks I used were Bilsteins and they were actually labeled for use with 0-2" of lift.
Old Nov 18, 2010 | 09:29 AM
wingman4's Avatar
I put an add a leaf in my f150 and never replaced the shocks... never had a problem. I put a 2.5" block in my tahoe and I replaced the shocks cause 1) they were shot; 2) they were reaching full extension with the torsion bars cranked just a little... I just got a set of Pro Comp RS(?)9000s from 4wheelparts. Drives awesome now
Old Nov 19, 2010 | 09:18 AM
Stevo2396's Avatar
Thanks for the help guys.
Old Nov 19, 2010 | 09:36 AM
Stevo2396's Avatar
I am debating whether to get a 3, 3.5, or 4 inch rear blocks. I know the stock blocks are 2 inches. Does anyone have any sugestions on what size would be best? I do alot of towing and currently my truck sags alot in the back.
Old Nov 19, 2010 | 11:26 AM
hoss66's Avatar
If you do a lot of towing i would recommend looking at http://www.summitracing.com/parts/FIP-2350/
Old Nov 20, 2010 | 09:26 PM
Stevo2396's Avatar
Thanks for the recommendation but i think im just gonna go with the 4" block. I wasnt looking at spending that much but may consider it down the road.
