Sponsored by: CARiD
Popping in the front
Old Oct 5, 2011 | 08:57 PM
pizzaman711's Avatar
Originally Posted by Jbaub
I have an 05 2wd with daystar 2.5" spacers leveling kit. It has been on for about 3 years and now it has started to make a popping noise when turning either direction. At first i thought it was my ball joints, so i replaced them with moog but the noise continued. I think my control arm is rubbing so I started looking at the bilstein 5100 leveling kit which would level it to 2" and improve my angles. Does anyone have any recommendations of something more i should check or about the 5100's. I just don't want to spend the money and not fix the problem.
Rancho quick lifts, and did you replace all 4? Also check tie rod ends, sway bar end links, etc?
Old Oct 5, 2011 | 11:25 PM
sbchris's Avatar
Check your lower control arm cam bolts. 99% of the time they are the problem and make a popping/clunk/glunk when loose.
