Sponsored by: CARiD
Questions after lowering.
Old Sep 11, 2010 | 05:42 PM
Hilgy_in_IA's Avatar
2006 F150 2wd 3/5 djm lower kit. I cut the tie rod end on both the male and female parts by 3/8" like the instructions say, then it says when you get the mounting arms up and the bolt through(this is in the 2 slotted parts), that you push the arm all the way back and tighten it down...well i did this and I could tell the rotors were angled bad...i dont know much about alignment but both sides the tires are pointed out quite a bit when I have the steering wheel in the "straight" position. what all needs to be done so this is fixed? Help please.
Old Sep 11, 2010 | 05:51 PM
Take it to get an alignment. That has to be done when the front suspension geometry is altered.
Old Sep 12, 2010 | 02:14 PM
Heres a few pics. Is this amount of angle fairly normal? What exactly to they do to correct so both point straight? These were with the steering wheel at the straight position.
By mark4h2001 at 2010-09-12
Old Sep 12, 2010 | 02:24 PM
kp02-150's Avatar
you've got wicked toe out. should be able to adjust it with the tie rod adjusters. there was a really good howto on driveway alignments a few months ago, that should show you how to do it.
Old Sep 12, 2010 | 03:19 PM
bankrpt's Avatar
Did you cut your tie rod like the instructions said you have to take almost a inch off each side edit just seen you did lol
Old Sep 12, 2010 | 03:24 PM
coobies5's Avatar
damn!
thats A LOT of toe out
Old Sep 12, 2010 | 05:35 PM
alex7191's Avatar
now thats its lower the tie rods are too long. that is crazy looking!
Old Sep 12, 2010 | 06:40 PM
Ok well update. Dont follow the instructions of pushing the 2 mounting bolts all the way back and tightening them down...I talked to someone on the phone and they said to loosen them back up and let the vehicle back down and turn the steering wheel 1 way then the other, and tighted each a portion at a time...I did this and it is fixed...looks pretty sweet!
Old Sep 12, 2010 | 06:50 PM
bankrpt's Avatar
We need pics of the entire truck
Old Sep 12, 2010 | 07:20 PM
PICTURES! Just took em with my phone and nothin on the truck is clean at all but its lookin pretty good, I'm happy with it so far. Thinking exhaust is next.
Old Sep 12, 2010 | 07:25 PM
FATHERFORD's Avatar
Now I know what my truck would look like with a flare side bed, lol.
What size tires do you have?
Old Sep 12, 2010 | 07:30 PM
coobies5's Avatar
looks awesome, but i'd get some different wheels
Old Sep 12, 2010 | 08:00 PM
bankrpt's Avatar
Looks great but im almost positive the tires are too big your going to be rubbing your front fenders.
Old Sep 12, 2010 | 08:41 PM
275/55/r20. Ive drivin it around and checked clearance around the whole fender guard and it doesn't touch anywhere when turning from one extreme to the other. Also my streets vary in quality with railroad tracks and I've tried it out all around town. There is a little knocking around in the back though as I drive it around, not sure what that is but i was gonna look at it tomorrow.
Old Sep 12, 2010 | 08:48 PM
FATHERFORD's Avatar
Your going to rub....
big bumps etc.
I have shorter but wider tires on the same wheels/drop kit. Mine rub.
