Sponsored by: CARiD
Blocks or AAL???
Old Sep 10, 2010 | 12:29 AM
offroadn'98's Avatar
Blocks or AAL???
I'm kinda getting tired of my truck sitting level. I don't kno that much about AAL's, is there any brands to avoid or what? My truck only has like 3 leafs so i guess that would add more strengh in the back? If i went with blocks, how big a block. i don't want the rear of the truck to be ridiculously jacked up but i wanna get the rake back i guess. How tall of block or AAL should i go with? pics?
Old Sep 10, 2010 | 12:41 AM
mudkickin4x4's Avatar
Well AAL will make the truck ride rougher, it doesnt bother me but might some ppl. Blocks are cheaper i think, espicially if you dont have any blocks then you can just pull them off of a stock f150.
But i would say AAL if your towing alot
Pros and Cons to both, just depends on what u need
Old Sep 10, 2010 | 12:44 AM
Woods-Rider's Avatar
You can also go with shackles.
Old Sep 10, 2010 | 01:27 AM
Well i was gonna stack another 2" block. I didn't kno the aal's make your ride rougher, but i guess it beefs up the rear a little. Is there any brands for aal's not to go with. i haven't looked at them yet.
Old Sep 16, 2010 | 06:47 PM
FX4SX's Avatar
Four wheel parts put a pro comp AAL on mine for around $330 installed. Pro comp is a good one
Old Sep 18, 2010 | 09:59 PM
2009KR's Avatar
I just stacked a 1" block on top of the factory block, which i got the block from fatbobsgarage. After putting a 2" AS leveling kit in my '09 4x4, the front was 3/8" high, now the rear is 5/8" high - perfect.
Old Sep 19, 2010 | 10:11 PM
hockeyfanjeff's Avatar
I bought BDS AALs in $100 for the pair a while back, shop charged $75 to install
Old Sep 19, 2010 | 10:59 PM
alex7191's Avatar
i honestly couldnt tell a difference in ride. it might be the same for you seeing as how we both have long beds with only 3 factory leafs.
Old Sep 20, 2010 | 01:57 AM
That seems like a pretty good price. You like the ride?
Old Sep 20, 2010 | 02:03 AM
Your prolly right. Does your truck get weighed down in the back as easily now?
Old Sep 20, 2010 | 04:56 AM
alex7191's Avatar
its stronger now. it used to drop down a little when i sat on the tailgate but now it doesnt move. i weigh 180. it brought it up 2 inches too
Old Sep 20, 2010 | 07:35 AM
freekyFX4's Avatar
I decided to go with a set of the Hellwig Load Pro helper springs. They are easy to mount and adjustable. The leaf pack does not have to be disassembled. They should be here in a day or two, and I will post pictures of the install. Here is a link to the install instructions:
Hellwig Load Pro Install
Old Sep 22, 2010 | 12:19 AM
Thats pretty good if it doesn't move with 180pds. I can put very little in my bed and i can tell it sags a little. Your trucks looking really good man.
Old Sep 22, 2010 | 12:20 AM
Thats pretty cool, i'll look into those for sure. Don't forget the pictures.
Old Sep 22, 2010 | 12:27 AM
Not bad at all, but then again I do have them paired with Bilstein HD shocks so it is stiff. Gained 2" easy
