sas info
I don't imagine the 460 needs more space than a modular motor will with that 90* platform.
He just responded to your thread, biggreen is the owner of the shop. He did even know the site was down. He is looking into it.
Does anyone know if using the pre-99 rear axles if you can run rear disc brakes? I used to drive a 94 Super Duty for work aka F-450 dually and it had rear discs. Also would there be somthing to do about the ABS light in the dash if I did use the older axles?
The abs light stays on, easiest way to get rid of it is with a black marker. Mine just stays on.
