Sponsored by: CARiD
2.5 in AS and bigger block
Old Aug 15, 2010 | 06:10 PM
FX4SX's Avatar
Well i know a lot of people run 37's with a 6" and a leveling kit. So either way im going to order a AS kit off of ebay. Should I go with a 2" or a 2.5"? I would rather have a 2" just so my truck stays a little more level and the angles would be smaller but im worried about rubbing. Do most people with this setup have 2" or 2.5"? (I know its not best to stack spacers.. I'm saving for coilovers and camburgs)
Also, I already have the pro comp block in the back stacked on the stock spacer of course (totals 4.5" of blocking). I added a 2" AAL because it sagged a lot in the back and still sits 3/4" lower in the back. So when i get a solid 6" block intead of the stacked 4.5" will i need to do anything to my Driveshaft?
Thanks guys i know its a lot.
Old Aug 16, 2010 | 12:00 PM
fx4 for life 79's Avatar
i would just get the 2" and you might have problems with drive shafts every truck is different
Old Aug 16, 2010 | 07:49 PM
HighOn22's's Avatar
Get the 2". I have a 2.5" and my angles are to much. In the fear I replaced to two blocks with a 5.5" and a 2 degree shim and a 2" AAL. My rear sits about 3/4" lower.
