6 inch backspacing...any lift options?
I am currently running 20x9 inch wheels 6 inch backspacing with 35 12.50 20 Toyo MTs and a 2.5 leveling kit. The tires rub slightly at full lock against the inside of the inner fender. I didn't have to do any trimming. In the winter I run a set of KMC Rockstars 20x8.5 and 6inches of backspacing with Super Swamper M16 35x12.50 20s. These fit and rub in exactly the same spot at full lock. I am wanting to go higher but I don't know if I have any option other than a Rancho 4inch. Is anyone here running anything other than the Rancho with 6inches of backspacing? Both sets of wheels/tires I have now sit close to the control arm on the inside of the tire, but they do not rub. I would like to do a 6 inch, but don't know if I will be able to use my wheels and tires.
