need a little more rear lift
Ok i have teh RCX 6" and front measures 46" and in the rear i have a 2" addaleaf and teh 5.5" block and it also sits at 46". I have a set of new Icon coilovers i would like to install but need a additional 2-3" of rear lift. any suggestions.. the plan is to get some rear deavers (4") eventually but 750 bucks plus the shiping may be off aways..
you never want to go more than 6" in block height and i currently have a 5.5 anti wrap block that comes with the 6" RCX kit With the 2" AAL and it is sitting level. so like i mentioned it looks like a lift shackle or leaf springs or a bigger AAl.. if rear springs weren 750 bucks it would be the no brainer .
the spacers could work but not sure where to put them with the aal and overload in there now, under the OL would be my guess but the anti wrap blocks have 2 small ubolts to help with axle wrap which i could find longer ones, but i just had to replace the ubolts when i put in the aal and would need to go longer yet ....dam ubolts were 60 bucks
I have mine close but I had to use the Rear shackle.
The 5" block gave me the 3" lift wich resolved the stacked blocks
the AAL 1.5"
The Shackle 1.5"
Total of 6" over stock in the rear.
My truck sits up 11" higher in the front. this includes the tries.
My truck sits up 7.5" in rear
[IMG][/IMG]
this is before I put the shackle in. I don't have a pick of after unles it is from a night run at the desert
the AAL 1.5"
The Shackle 1.5"
[IMG][/IMG]
Larry you truck looks great.
It is funny though after looking at the truck and a tape measure we all seam to go off the grount to the top of the wheel well. mine is currently 46" at both. but if you measure the front door glass and to the back of the top of the box i have a 1.5 rake to the truck. i think that is where it was getting confusing. so i may stick the coilovers in crank them to add a inch or so.. i just hate to go a inch and then later 2" and have to do a alignment in between each cranking.
Stock
frt 36" Rear 39" at wheel wells no camper shell
Lifted
Frt 47" Rear 46.5" at wheel wells W/camper shell
