Sponsored by: CARiD
skyjacker add a leaf?
Old Apr 19, 2010 | 04:48 PM
emeany150's Avatar
i have the 2.5 leveling kit and it sits about level, but when i add weight to the bed and tow the fronts sitting up high and the rear is lower, what are the positives and negatives of a add a leaf?
Old Apr 19, 2010 | 04:55 PM
FlashmasterK's Avatar
The positives are this site has a search function. The negatives are this site has a search function. Come on man, this info is easy to find
Old Apr 19, 2010 | 05:43 PM
Dog'em's Avatar
Since you have posted the same question twice in about the same amount of hours I will help you out so you can move on.
Benefits : Sits level when towing or hauling. Needs no other modifications with your level kit. Easy to install and cheap.
Negatives : Rides a little stiffer when empty and has a slight back to front slope or rake when empty.
Good luck
Old Apr 19, 2010 | 05:45 PM
wes1333's Avatar
You can also just add a 1inch block to the rear cheaper route.
Old Apr 19, 2010 | 08:25 PM
emeany150's Avatar
thanks, i just joined today and i wasnt shure where to locate all this info, and next time i wont post it twice lol
Old Apr 19, 2010 | 08:52 PM
Rotested's Avatar
Another option would be the Firestone Ride Rite Air Bags in the rear, they cost about $250 but are much easier than an AAL to install. I have these and love them. For example, my truck is an 08 FX4, I have a 2.5" leveling kit (AS) as well and my truck behaves exactly like you say yours does, level when empty, noticeably nose high when loaded. With the bags, I run about 15 psi all the time which gives me about 3/4" lift out back with no noticeable change in the ride (not stiff like AAL's). If I need to, I just add more air to keep it level. At 100psi, I get about 4" lift when empty. I just ran the schrader valves out to the back where 2 of the license plate screws were for easy fill ups. Another $250 will get you an onboard compressor with a guage and buttons to inflate/deflate from inside the truck.
Old Apr 19, 2010 | 09:11 PM
emeany150's Avatar
that is another option i will look in to thanks
