Sponsored by: CARiD
"Death Wobble"
Old Feb 18, 2010 | 02:55 PM
bigsur's Avatar
"Death Wobble"
Anybody with lift kits, leveling kits, or larger tires experiencing this? Twice now I have been on the interstate over 65mph and my steering has started to shake back and forth...somewhat violently the first time. This never happended until I put a 2" Readylift and "slightly" larger tires on. Nobody can tell me what it is. I've just heard it referred to as "death wobble".
Old Feb 18, 2010 | 03:23 PM
fx4 for life 79's Avatar
did u get a alignment afterwards?
Old Feb 18, 2010 | 03:40 PM
Windsor's Avatar
It's usually a loose steering component that causes the wobble. Make sure you tightened your ball joints. If you haven't had it aligned, that might also be contributing to it.
Old Feb 18, 2010 | 04:02 PM
ridemx's Avatar
Alignment being off or bad/lose ball joints , Tie-rod ends, or other steering components are by far the most likely culprits.
Old Feb 18, 2010 | 04:03 PM
lost cause's Avatar
i had a death wobble when my pitman arm went bad. i replaced the idler arm, pitman arm and it went away. i would check those.
Old Feb 18, 2010 | 04:04 PM
bigsur's Avatar
Yes...the shop that installed the kit and tires did an alignment. Also, a week later I hit the biggest pothole I've ever hit and it shifted my steering wheel off center so I had the dealer do another alignment. Ford said I might need to install stabilizer. Might be one of other issues stated above though.
Old Feb 18, 2010 | 04:10 PM
BlueOval_Man's Avatar
I'd say your steering could be lose. My buddy had the worst death wobble and all it was a bolt loose. I mean it shook his dash off, hence why I hate Jeeps.
Old Feb 18, 2010 | 04:32 PM
id get the shop to retighten everything if they havent already, or one of the above statements could be causin the problem
Old Feb 18, 2010 | 04:38 PM
sbchris's Avatar
Wrong year, he has a rack and pinion system.
Your inner tie-rod could be loose from that pot hole and or damaged. Have a shop check them out who knows what they are doing. Most 50 dollar alignment shops don't even know what an inner tie-rod is. This is the section of the tie-rod on the rack side and not the spindle side.
Old Feb 18, 2010 | 04:40 PM
lost cause's Avatar
when mine had the death woble it occured after i had hit a hole pretty hard. then it would wobble everytime i hit a bump in the road. it ended up being the pitman arm. I would check to see if everything is tight like stated before, but if everything is tight i would look into replacing the pitman arm and/or idler arm.
Old Feb 18, 2010 | 08:56 PM
bigsur's Avatar
All good advice. Thanks guys. Should have it in the shop next week hopefully.
Old Feb 18, 2010 | 09:31 PM
Beastly_95's Avatar
i had it and it was tie rod ends
Old Apr 19, 2010 | 03:44 PM
Tumba's Avatar
I found this thread while doing a search on this subject. Recently we replace ball joints, tie rods inner and outer and got an alignment.
The truck just started doing this again.
I put it on jack stands and got underneath it and push beck and forth on the tires, one with my foot and the other with my hand. I'm getting some slack from the steering gear box. The Pittman and Idler arm doesn't have but a fraction of movement, But the gearbox looks like it has quite some distance in it.
Has anyone else noticed a problem like this?
The truck has 183 k by a younger driver. But mine has 204k and no slack at all. I'm just wondering if anyone has had this problem.
Old Apr 20, 2010 | 04:57 PM
bigsur's Avatar
I wouldn't know....I personally don't have the mechanical know-how to check it myself. My dealer checked my truck and said it could be a number of things, but that I might want to consider installing a front-end stabilizer, which may or may not resolve the problem.
I still get it but very seldomly....has only happened 2 or 3 times since I installed new tires/rims and always at a high speed.
Sorry I couldn't be more help.
