Sponsored by: CARiD
shims 5 & 6 degree
Old Apr 8, 2010 | 06:32 PM
sbchris's Avatar
shims 5 & 6 degree
Before I order some metal stock to make some shims for my truck, does anyone know of any place that sells 3 inch wide shims with a 5 or 6 degree angle?
Not looking to weld two sets of 2.5's together...
Thanks!
Old Apr 12, 2010 | 04:12 PM
sbchris's Avatar
Just an update for people in this situation.
Best I have found is national sells a 4 degree shim.
Old Apr 12, 2010 | 09:38 PM
mhockey9090's Avatar
Good luck on finding atleast something but ill try to do some research myself man. Best bet is maybe have someone make you one
Old Apr 14, 2010 | 01:53 AM
sbchris's Avatar
For 5-6 degree in 3 inches it is sounding like they need to be custom made.
I'll report back when I put in the national 4 degree's, I'm not expecting much though.
Old Apr 21, 2010 | 02:48 AM
sbchris's Avatar
Got the shims and they are not a bolt on type deal at all. They are for a mopar looking at the box and the shim has a tiny hole on it made for a single center pin. I machined these guys to make them fit with the dual pin setup, pretty easy. The vibration is a little bit better but it is still there Starts to come back a bit around 80+. I'd guess a 6 degree would make it a little bit better but I could be wrong.
I'll have to pony up for a new drive line here in a bit.
