Sponsored by: CARiD
What is needed for alignment?
Old Mar 31, 2010 | 09:39 AM
Helrazr's Avatar
I have 6 inch ProComp and 5.5 rear lift block. I would like to lift the front enough to level out the truck 1.5 or 2 inches. I recently had the alignment done on my truck and was told that the cams are at the end for adjusting camber. What is needed to correct alignment if I go higher.
Old Mar 31, 2010 | 12:11 PM
wandell's Avatar
Did the Pro COmp kit come with adjustable camber bolts? If not, you will need to add them. They are about $50 at most auto parts stores.
Old Mar 31, 2010 | 10:36 PM
Helrazr's Avatar
Yes I have the adjustable bolts, is there a off set ball joint for the knuckle? Please advise.
Thanks,
Chad
Old Apr 2, 2010 | 07:52 AM
Helrazr's Avatar
Anyone???????????
Old Apr 4, 2010 | 11:42 AM
Shepard69's Avatar
Thanks,
Chad
You can get adjustable top a-arms. They will help with the alignment. I am in the same boat, just can't justify the cost yet. They are made by Camburg
http://www.camburg.com/images/05tacoma/taco_bj_uca.jpg
The pic is from a toyota, but they make them for the f150
There is also a kit that places the top a-arm bolt with adustable cams, kind of like the bottoms bolts. Can't remember the link. Just google
