Sponsored by: CARiD
will 35s scrub with a leveling kit ?
Old Mar 11, 2010 | 10:04 PM
ga.dawg's Avatar
im planning on puting a 3in. level on my 03 4x4 screw and cranking the torsion bars a little bit. will i be able to put 35s on it ?
Old Mar 11, 2010 | 11:37 PM
IronMedic's Avatar
from what i learned, u cant run 35's on a leveling kit of any type without a full lift kit.
Old Mar 11, 2010 | 11:41 PM
nick.schrandt's Avatar
stock rims or aftermarket?
I had 33.9 in tires on mine a while bark with no torsion twist I think it would be a very tight fit but maybe doable
Old Mar 11, 2010 | 11:42 PM
hunterjh's Avatar
With the kit and stock rims youll definitely fit them easy.
Old Mar 12, 2010 | 12:34 AM
dilloncawthon's Avatar
well a leveling kit for your truck is just reindexed torsion keys. so it just cranks your torsion bars to the max which is very bad, also you couldn't crank your torsion bars any more after installing it.
Old Mar 12, 2010 | 08:39 AM
ga.dawg's Avatar
oh ok well i'd be puttin aftermarket rims on it
Old Mar 12, 2010 | 11:03 AM
wandell's Avatar
You are about to waste money and destroy your front end. Either crank up your torsion bars with the stock keys and run 35x12.50 tires on your OEM wheels or 33's on wider aftermarket wheels or install a 3 inch body lift and then run 35's with wider wheels.
Old Mar 12, 2010 | 04:26 PM
fx4 for life 79's Avatar
yes i agree with wandell and dillon, just crank your tbars now and dont bother with aftermarket keys, ive seen where my friend bought aftermarket keys and cranked some more on top of that and his front end just collapsed on the tires, but it was a chevy 2500
Old Mar 13, 2010 | 12:34 PM
mshane1's Avatar
Here is my 01 with just the tortion bars turned up and 35s on it. I moved back my running boards and took off the lower front plastic piece. No rubbing at all so it will work. I do have 17x9 helos not the stock rims though.
