My 2WD needs to look bigger!
I drive an 06 2wd f150 and it just sits too low, im not lookin to
spend too much money but want it bigger to fit 33's.
So far ive been thinking the 2" or 2.5" AS leveling kit, but my
friends been talking me up to a 3" body lift. Im also down to
crank the torsion bars (unless thats only 4x4), but not sure if thats damaging to the
truck or the ride. opinions greatly needed and pictures of what
other people have done to there 2wd's would be awesome
Not sure on the 04-08's. I hear they are a pain to install on your truck though. If you have to pay someone to install it and a leveling kit, you will be about as well off installing a 6 inch Stage One Pro Comp lift.
you can easily clear 33s with the 2.5, but your rear will sag. AS sells blocks for the rear that are 1.5 or 3" depending on what you want. the shorter block will level a 2wd and the 3 will give it a slight rake (its really made for 4wd trucks with a level). i went with the 3 and am very pleased. i have pics in my profile of what it looks like with just front and then rear added if you want an idea of how it might look.
i did the 2.5" level kit and 2" block for the back. to me a slight rake but close to level and i love it. cost me about 220 and did the work myself. i would do that first and if you want more than do body lift. my opinion. body lifts are a pita for ours and cost between 500-600 for installed. although they are not a bad option for a slight rise.
you'll fit 33's no prob. 35's maybe will fit with less aggressive tread and minor trimming. good luck.
