Sponsored by: CARiD
Differential drop brackets
Old Jan 21, 2010 | 01:15 PM
rydin4life's Avatar
Hey everyone sorry if I should have put this in the powertrain section but I have a 4 inch trailmaster lift with the tosion bars cranked. The trailmaster lift came with differential drop brackets however I guess they aren't long enough because my brand new cv joints knock when I turn sometimes. Do you think I could fabricate some longer drop brackets so I don't blow through cv joints? I don't want to lower the torsion bars because the truck is aligned at it's current height. Thanks for any input!
Old Jan 21, 2010 | 05:44 PM
Ibrocun's Avatar
Which kit is it? Trail Master was purchased by Performance Automotive Group (Performance Accessories) in 2005. They re-engineered a lot of the old kits. The old kit is a bracket kit, the new one is a knuckle kit. If you are having an issue with one of the old ones, get a new one! If it's one of the new ones, you should call PAG at 928-636-7080 and talk to the techs.
Old Jan 21, 2010 | 06:28 PM
rydin4life's Avatar
It's one of the old ones which uses brackets. It had no knuckles. But I'm not about to spend 1500 bucks on a new kit if I could just fab up longer brackets
