04-08 4wd shocks on a 2wd? Any thoughts
My buddy has a 2wd 04 f150 and he wants more height. He already has a 2.5 inch leveling kit and the front fenders are about level with the rear. Is i possible to put 4wd shocks on his truck and add a leveling kit?
did a search and there hasnnt been proof that someone has done it and there is alot of back and forth but i found a post that sums it up pretty well.
Read post 17
https://www.f150online.com/forums/su...alled-2wd.html
Read post 17
the suspension may look similar...but the geometry is totally different. a 2wd with 4x4 shocks will not have the same controll arm angles as a stock 4x4. The controll arm angles on a 2wd with 4x4 shocks will be similar to a 4x4 truck with a leveling kit. Make sence?
If you combine a leveling kit and 4x4 coilovers on a 4x2 I don't think you could even get the front end bolted back together because of the severe angles.
