Do Bigger Tires Require Alignment?
There is only a 6 mm difference between Roush's offset and Fords. That's less than a 1/4" difference. I wouldn't expect needing an alignment if you were within a 1/2" change in offset from stock. It's easy enough to measure the ride height before and after the wheel swap. If it changes more than a 1/2", I'd get it aligned.
Tire height will not change the alignment. What I meant by changing ride height would be swapping the rims with his current tires and if it changes by more than 1/2", an alignment is probably in order.
