Sponsored by: CARiD
98 dual steering stabalizers
Old Dec 25, 2009 | 06:52 PM
98ridinhigh's Avatar
Hello everybody I finally got some money to buy some much needed steering stabalizers. I have a 98 and I cant seem to find any dual stabalizer kits for it. I have to get the dual kit because I have 39.5's on the truck and the steering wheel does shake quite a bit. I found that skyjacker makes a kit but it says 'made for use with skyjacker kit only'. Im not sure if they say that just to get you to buy the skyjacker lift kit or what. Anyhow I was wondering if anybody knew if they make a dual stabalizer kit for a 98 4wd and where is the best place to get it. Thanks for any help!
Old Dec 25, 2009 | 10:17 PM
4x4wolf's Avatar
I have the skyjacker one, haven't put on truck yet though. Instructions say where to install it if you have it stock or with a 4 inch lift or bigger. So I'm going to put on my stock suspension truck so I bet it'll work on your setup
Old Dec 26, 2009 | 11:35 AM
Ok im just not sure if it will work with the rough country lift kit so im hesitant to buy it
Old Apr 24, 2010 | 02:27 PM
4x4wolf's Avatar
Just a update: Finally installed mine and for a stock truck you need to trim a little off of one of the brackets or the bracket will hit the four wheel drive actuator when fully turned to the right. But on a lifted truck I'd have no worries.
